Epic lenght lock system
14 years 9 months ago #7553 by Hiro
Replied by Hiro on topic Re:Epic lenght lock system
Orderd the lever from Epic Australia today and...finaly received an answer from Epic international, they say that as these are precise components they have to use special jigs to calibrate the installation, with a special adhesive, and its possible my ferrule may not be compatible.
I'll let you know how it goes when I receive the lever lock.
14 years 9 months ago #7558 by [email protected]
Bit late in the day to reply to this topic :unsure: but I have two Epic mid-wing paddles; one with the old-style length lock and one with an early release of the new lever lock.
The lever lock mechanism rusted up and eventually seized. Epic sent me a new one - entire collar mechanism - and I had it replaced. Then I had the old length lock replaced with a new one lever lock too. The old paddle's markings don't match - but that's ok I've marked it myself.
But I much prefer the lever lock - and since I had the new ones fitted, I've had no problems at all. Clearly the newer ones have a better grade of stainless in the fitting.
Just as a side note, I always rinse the paddles and lock mechanism after paddling...
14 years 9 months ago #7561 by Hiro
Replied by Hiro on topic Re: Epic lenght lock system
The Epic sold in Tahiti fited with the lever lock were the first ones with the crapy steel mechanism, but Epic contacted every buyer and sent them a new stainless steel part even before they started to rust... was a 5 minutes job to change that part and only needed a screwdriver.
14 years 3 months ago #10028 by Hiro
New lever lock, and old twist lock that needs to be taken away from shaft.
14 years 3 months ago #10029 by Hiro
Boiling water helped to soften the glue.
Lock being separated from shaft with a blade.
14 years 3 months ago #10030 by Hiro
voilà
14 years 3 months ago - 14 years 3 months ago #10031 by Hiro
The inner diameter of the lock is bigger than the shaft. Need to find a way to keep it aligned while the epoxy cures. Inserting the shaft of the other half paddle is okay but it might get glued :S so I wraped it with a layer of aluminium foil (doesn't stick to epoxy).
Works perfectly, paddler is happy !
Last edit: 14 years 3 months ago by Hiro.
