Speedometer
11 years 11 months ago #21269 by Abel
Speedometer was created by Abel
I have seen on the internet individuals who have a large screen speedometer on their surfski. What company makes those??
11 years 11 months ago #21276 by Ric
Replied by Ric on topic Speedometer
Sounds nice - show us a link pls?
11 years 11 months ago #21277 by Jmuzz
Replied by Jmuzz on topic Speedometer
Hiking GPS perhaps?
Phones can do a good job too these days, if you can rely o. The waterproofing.
11 years 11 months ago #21279 by LaPerouseBay
Replied by LaPerouseBay on topic Speedometer
Phone apps are out there for other sports and probably cross over, but these units are designed for paddling. They are too spendy for me.
I get by with my garmin 310 and pass on the real time viewing of speed because I only downwind. I do like to overlay the data on my videos.
310's sample rate for speed is 1Mhz, which is ok for me, but the rowing unit below is 5Mhz, which should be considered if you want accuracy. They also have a wired impeller, super accurate.
www.nkhome.com/rowing-sports-products/speedcoach-gps
If I did flat water, this thing would be on my list. Not really practical at my skill level (Oscars drills are humbling!) but I love the gizmos.
www.kayakpowermeter.com/
11 years 11 months ago - 11 years 11 months ago #21283 by RedBack
Replied by RedBack on topic Speedometer
The Garmin Edge Units have a large screen that can be user-configured to display the data that is most important to you during your paddle.
I have mine set up with just Speed, Elapsed Time and Heart-Rate for races, but if you have an ANT+ enabled instrumented paddle such as one from "One Giant Leap" (www.kayakpowermeter.com) then for training you can also have it display cadence and power and record "power-over-time" for later analysis.
Details for the Garmins are here:
buy.garmin.com/en-US/US/into-sports/cycl...rts-cCycling-p1.html
Yes, they're cycling computers, but they work very well on a ski/kayak as well...
Edit: Whoops, just noticed LPB's response above. Sorry if I duplicated info already provided...
Last edit: 11 years 11 months ago by RedBack.
11 years 11 months ago #21284 by Coast Steve
Replied by Coast Steve on topic Speedometer
Good topic Abel!
I'm also looking for something.
You may just be looking for a portable GPS?
I once had a "Speed mate" actually I still do.
BUT I always lost the little impeller so I gave up on it altogether.
It did the distance and speed and that's all I needed.
I see the new "speed coach" says it works without an impeller.
It also does paddle strokes...cool.
I wonder how they do boat speed without an impeller?
If that's the case I'll be interested.
Weeds and logs in my area you see that rip off the impellers.
The new "power meter" is WAY too much money for me.
There must be something else.
Steve
NELO K1 Flatwater
26 foot montgomary OC1
(Seven Of Nine)
11 years 11 months ago #21287 by Chookman
Replied by Chookman on topic Speedometer
The NK Speedcoach has a wired pick up sensor; however the impeller is wireless... it mounts to the hull and sends a signal to the impeller. The only issue with the Speedcoach is it doesn't display km/h. It displays knots, m/sec or 500m pace. There is another unit called the Speedwatch which works on the same principle. It is very accurate and reliable, and displays km/h along with several other options. For flatwater, especially on tidal rivers, these are far superior to GPS. I've used the Speedwatch for several years now and it's been faultless. The only drawback with the Speedwatch is having to regularly replace the 9v battery in the transmitter, and although the user manual doesn't mention it, the battery should be removed after every session as the transmitter is very sensitive and will keep ticking over whenever it is near an electrical source, eg wires, fluorescent lights etc.
11 years 11 months ago #21288 by [email protected]
Replied by [email protected] on topic Speedometer
(A couple of posts on this thread were flagged by the spam checker... all fixed now, sorry about that.
The spam checker is working well, and has seen off a number of spammers before they dropped their stuff onto the forum. This is the first time it got it wrong.)
11 years 11 months ago #21291 by LaPerouseBay
Steve
GPS.
11 years 11 months ago - 11 years 11 months ago #21292 by sAsLEX
Replied by sAsLEX on topic Speedometer
LaPerouseBay wrote:
Steve
GPS.
GPS only gives speed over ground, not speed through water. Paddle on a river and you might be moving the boat upstream at 4kmhr but paddling at 14kmhr.
I would use a Hall Effect sensor......
Last edit: 11 years 11 months ago by sAsLEX.
11 years 11 months ago #21300 by uk_exile
Replied by uk_exile on topic Speedometer
One of the highly accurate competition slalom water ski speed control systems averages passes in both directions hence can work out current if skiing on moving water. Devices for rowing or kayak could do same or drift on no wind day. Of course not as accurate as proper water speed sensor as current, tide, localised flow & eddies etc
11 years 11 months ago #21302 by Chris C
Replied by Chris C on topic Speedometer
robin.mousley wrote: (A couple of posts on this thread were flagged by the spam checker... all fixed now, sorry about that.
Yep, it did the trick alright (I am formerly Chookman). It locked me out of the site totally and the only way I can get back on was to create a new account using a different computer! :unsure:
11 years 11 months ago #21303 by Chris C
Coast Steve wrote: Good topic Abel!
Steve
Speedmate was the best unit ever! Totally wireless and simple to use. Such a pity NK no longer make them.
If you still have yours, just buy a replacement impeller fron Nielssen Kellerman - they only cost around $30-40. The impellers used on the Speedcoach units are identical to those supplied with the old Speedmate.
11 years 11 months ago #21304 by Chris C
Why are my replies not being shown?
11 years 11 months ago #21306 by [email protected]
So sorry Chris - new users have their first two posts moderated, again to stop spammers.
I thought I'd fixed your login after the spam checker zapped your original post, but I hadn't completed the task. It should be fixed now, please try again.
Apologies!
11 years 11 months ago - 11 years 11 months ago #21331 by Coast Steve
Maybe you're right Abel about the impeller.
I'll look into a place to get a few.
I'm really bad at knocking them off into the water though.
Too bad mine doesn't do stroke rate too.
NELO K1 Flatwater
(Seven Of Nine)
Last edit: 11 years 11 months ago by Coast Steve.
11 years 11 months ago #21332 by sAsLEX
Coast Steve wrote: Too bad mine doesn't do stroke rate too.
www.vaaka.co.nz
These do cadence, work well with Garmin watches
11 years 11 months ago - 11 years 11 months ago #21336 by Coast Steve
Well I decided to keep my old faithfull "Speedmate"
I just ordered a couple of the fins with new impellers today from the US.
Just not in the budget right now for a fancy and almost $1000 system.
At least I will know my top speed, distance, etc.
Abel, let us know what you get when you decide.
NELO K1 Flatwater
(Seven Of Nine)
