- Thank you received: 57
Newbflat wrote: I'm thinking of picking up a Garmin 310xt but I'm curious how fast it updates speed. The Garmin 76CSx I'm using now updates about once a second more or less. Is the 310xt slower?
Smart Recording records key points where the fitness device changes direction, speed, heart rate or elevation. This recording type allows the user extended recording time given that it is recording less track points, thus taking up less memory.
Every Second Recording records the activities information every second no matter if the device changes direction, speed, heart rate or elevation. This recording type provides a more defined track log of your activity. However, recording time will be reduced given that it taking up more memory.
Kayaker Greg wrote: I have both and you will find the 76CSx updates the speed much quicker and is more accurate. Quite noticable when you first change from the 76CSx to the 310xt, but you get used to it lagging behind.
Kayaker Greg wrote: I wouldn't worry about it, just use the Garmin 310xt, you will get used to it lagging a bit. I used to mount the 76CSx in its dry bag to a couple of strips of velcro mounted in front of the foot pedals, the numbers are large enough to read from there, tethered of course, now I just use the 310xt, for sea kayaking as well, only use the 76CSx when I need the maps or looking for a campsite for eg.
