Repairs To A Rudder Cable.
16 years 2 months ago #4496 by wrsteane
A Fairly newbie,
After snapping a rudder cable on an older model surf60, and losing the loose end, Stern side, into the boat, was wondering as to how to go about effecting a repair, if possible without compromising the hull? Is going into the hull they only way to sort out this problem>? Is there an outer casing in which the cable runs to make replacement easier? Resident in Port Alfred, so would the best option be to take the ski into the factory?
Many Thanks
Warwick
