- Thank you received: 42
Rightarmbad wrote: As promised, I have half an hour of Anaconda giggles.
The 3 meter seas didn't turn up, but a few good sets coming through caught a lot out.
Now how do I edit it and compress it to present here?
MhojoNZ wrote: Just a comment - you seemed to have a similar paddling fault to me (for which I am always being told off for), which is not extending your top arm fully. You will get more rotation and a more forward entry if you get your arm fully extended.
Dicko wrote: I've had a Vault for a week or so now and like most new toys I've now had about 30 paddles.
Dicko wrote: The boat tends to wander a bit on a confused downwind and I think a new more balanced rudder will solve the problem. The best thing about this boat is its ability to draft. It catches any small lump. Really good boat. Fast if you've got the motor to drive it, and almost beginner level stability. I just don't like the standard rudder, with the post at the leading edge. You seem to lose a degree of manouverability (where's spell check) across the wave.
ts-d wrote: hi ar_convert,
this is the normal rudder and the large rudder side by side
They aren't very different in size.
I would be very interested in your experiences, because my vault is ordered for April 2012, is it better to take the traditional rudder as Hein says or the large one? Thanks!
Dicko wrote: The problem isn't so much the size, it's where the shaft is placed. When the shaft is too far forward the rudder is ok at low speed, but as you build speed on a wave it creates a lot of "lift" behind the shaft and suddenly it requires a lot more foot pressure
to turn the rudder.
Dicko wrote: I have ordered the eliptical rudder from Hein
Kayaker Greg wrote: What do people mean when they say "rudder stalling"? What does the rudder and ski do?
