- Thank you received: 138
kiwial wrote: Too short on the catch
(because of) not enough rotation
(and) arms not straight at the end of the push phase
possibly pulling too far back (hard to tell with the footage used)
get some dedicated footage and I'll be able to give better help
Al
Rightarmbad wrote: Forget about the stroke; how did that guy fall out in that almost mirror conditions?
Dicko wrote: I'd also forget about the stroke and get a haircut. I reckon you could get about 2kmh quicker with the reduced wind resistance.
Rightarmbad wrote: It's just like swimming, reach forward and get a good catch before you pull.
I'd put you on a 210cm or less paddle, this will encourage you to reach forward more before you start the stroke.
Rightarmbad wrote: My paddle hits the water about 30cm in front of my feet, goes vertical very quickly as my top hand comes across, then the foot pushes and the whole torso rotates with the paddle still vertical and then comes out as soon as the thigh on the pushing leg touches down (or close) to the hump.
Happy thinking, and do try a shorter paddle if you can.
Foot drive should be on same side as paddle stroke to maximise rotation
