- Thank you received: 42
I tried to focus on that during yesterday's paddle : use the lateral support you get from the water into a forward motion... not easy.Note that Kemecsey is not saying that edging the kayak, "locks it" in the water. His belief is that if you press (not edge) the kayak against the "water wall" (water pressure) on the non-stroke side, combined with the paddle thrust on the other side, that the kayak will shoot forward (like squeezing a bar of soap) and will run straighter.
Sitting higher gives you a longer, more powerful stroke, since there is more distance between your hands and the water. However, I think it's overrated. The VAST majority of paddlers are better off sitting lower and more stable. Increasing the seat height by 20mm theoreticially may give 0.5% more power, but more often than not will result in 10% less power because technique then suffers due to instability.
