Repairing Carbon Paddle
17 years 6 months ago #2673 by Madgus
Does anyone know how to remove the blades from a carbon shaft.
I snapped the shaft at the joiner last week and want to put the blades on a new one? I will attempt to remove the snapped internal section of the joiner first, but I suppose the technique is still the same.
I presume you would have to use heat, if anyone has any first hand knowledge it would be greatly appreciated.
17 years 6 months ago #2674 by YBA/Jim Murray
If hot melt adhesive was used you can use hair drier or boiling water to take apart a socketed blade. If glue was epoxy or something else it may be possible to clean mechanically with a die grinder. If paddle blade is not socketed, but slides into shaft, you should use epoxy or even GP polyester resin Plus a reinforcing wraps of one inch fiberglass tape around shaft ends.
