- Thank you received: 44
I use some high density PVC foam and shape it to the footwell and screw and glue from the top, using the same holes originally used for the rubber bumpers. You can make it as wide as you like to transfer the load.
Super helpful, your orbitness.In case anyone is in position to 3d print, here is what I have designed for my 520:
www.thingiverse.com/thing:5530831
Ideally you would print with TPU because it's soft and will conform better.
EDIT: Actually it needs to be soft for assembly, so *must* be TPU.
One of the kids has a 3D printer, I'll ask if they can print this.
