- Thank you received: 29
SpaceSputnik wrote:
To me 75 percent is quite good. The only question I would be asking myself us whether it is safe to continue at all. If it is I would continue simply because I love paddling.
Can you not adapt? Say take your safe effort level and increase the distance. I personally love the idea of being able to cover say 30-40 k at a time. I would probably even prefer that as a goal over shorter oomph.
Since my first surgery in 2005 I have been pretty consistent with training both for strength and flexibility. I think were it not for those efforts I may not be able to use my shoulder much at all today.Davidw wrote:
If you are able and If you don't already do strength training I'd strongly recommend it, specifically a protocol like Pavel Tsatsouline's Simple & Sinister which I've found to be pretty kind to shoulders as strength programs go.
Yip, this is very true. I have been at this for fourteen years but the initial damage was pretty severe and then over time more and more damage.Davidw wrote: But patience is required. It's not an overnight fix.
I actually started with low elbows and then over time changed my stroke a bit to where I am now which is the most comfortable for me.Why are you paddling? Relax and have fun.
Most important is your stability, a stable craft will enable you to paddle correctly without any issues.
One piece of advice on your stroke: Keep your elbows down at all times. Generally lifting your elbows will cause your problems.
Watto wrote:
Sorry to preach cobber but is true.Be your own hero. Suck up the personal disappointmen and get on with doing what you can. My immediate goals are The Doctor 2019, Mauritius Ocean Classic 2020, Rottnest Channel Swim solo 2021 (on my 70th) and then around Australia on my motorbike. Not valorising myself Manta, there are others doing much bigger shit out there, just saying, don't give in to it. I'm being my own hero and I'm good with that.
Teddy Roosevelt: Do what you can, with what you have, where you are..
