Take your boat length and divide by 3 or 4.
3 is easy, place a support at 1/3 and 2/3 of boat length. This will leave slight gravity pressure on the ends
assuming a boat is perfectly symetrical weight wise, if you divide boat length by 4 and place the supports at 1/4 and 3/4 the boat should be totally balanced. My guess is there is likely more weight in the nose, so my statements are probably off somewhat, but I wouldnt worry.
Personally I've hung all my boats (V10, SR, XT) with 1" nylon strap at approximately 1/3 and 2/3 support points and had no problems what so ever. Probably just dont put the straps at the extreme ends or too close together. Anything in between is likely ok,
I would mostly be concerned about avoiding pressure points/puncture points from any sharp edges, screws, hardware etc that you use to make the hangers.
Congrats on the new-ish evo
