- Thank you received: 2
Hiro wrote: You will remain submerged... but only if your legs are 30cm long...
Fath2o wrote: Sputnik, I'm curious. Does Canada have a system similar to the
"Rescue 21" system we have in the US?
wow.uscgaux.info/content.php?unit=170&ca...-vhf-radio-rescue-21
rickbinbc wrote: If I'm not mistaken, you would need a portable VHF radio with GPS capability to use the DSC feature. Looks like they are available on Amazon for about $CDN 360.
I have an older Standard Horizon HX270S that would require me to use channel 16 (Canada International Distress Channel) and manually make the call.
tve wrote: FWIW I went through the "what radio do I buy" stuff a month ago and ended up with the HX870 and so far am very happy. I carry it in the front pocket of my mocke PFD and it has not disturbed me when remounting even though it's rather thick. I did make several DSC test calls to verify that the CG can receive my transmission. My recommendation would be that if you go out alone to get a DSC radio, else stick with a simpler, cheaper, smaller radio.
