- Thank you received: 411
Hey Tinus! It's supposed to last for 12 hours, and judging by the comments on user groups, that's accurate. I usually paddle with it switched off but that does mean having to wait while it acquires GPS signal before you can use the DSC emergency button.How long does the battery last on one of those units?
You can surely call for help straight away, then once GPS acquired pass DSC information?robin.mousley wrote:
I usually paddle with it switched off but that does mean having to wait while it acquires GPS signal before calling for help.
Yes, of course.You can surely call for help straight away, then once GPS acquired pass DSC information?
Very true!Rob, you mention that it floats but is it water proof? Not the same thing
Yep, I did. I had to wait for the radio to acquire the GPS signal first, which took a couple of minutes.Did you try the DSC / GPS stuff?
I suspect you're being facetious, but I'll reply as if you're not. 1) there's no way to fit such a thing on a radio. 2) if you did, it would make the radio impossible to store in a PFD pocket and 3) that thing would itself get soaked and provide an even greater barrier to speech.Did you think to try a fluffy mic cover noting your radio is already waterproof?
Seasurvival wrote: Howzit Rob,
I have laid out for one of these DSC handsets, and have a VHF operator license. Do you have a direct contact at ICASA to get that MMSI registration done? I am struggling to make progress via their website.
