- Thank you received: 411
Hi Rob, hey head north to Pelican Point Namibia where they get about 8mm of rain annually. Leave it there, it will be fine.What can I do to waterproof the darned thing?
Hahahaha!Hi Rob, hey head north to Pelican Point Namibia where they get about 8mm of rain annually. Leave it there, it will be fine.
How vigorously do you rinse it? Do you shower with it on?My one has worked for years, just replaced battery once a year.
Hey Watto,Rob, stored with (in open air) or in your pfd? Left all my wet kit inadvertently in my Mocke bag in the car for a day or so recently and sure enough the Garmin Run HRM (an oldie) had internal corrosion.
I think you're right! Happily I happened to find a tube of o-ring grease (came with an underwater camera housing), which hopefully has a more compatible formulation! Duly slathered, I've used the belt twice so far, keeping my fingers crossed.I'm no chemist but apparently Vaseline is no good for O rings. Silicon grease is supposed to be much better for them.
