Epic V-12 body fit?
13 years 8 months ago #14093 by 1xsculler
I'm 6' 2" (188cm) tall, weigh 160# (72.7 kg) and have a 34" (86.4cm) inseam. Would you expect an Epic V-12 would fit me?
13 years 8 months ago #14098 by Rob1
Replied by Rob1 on topic Re: Epic V-12 body fit?
I am the same height as you however slightly heavier, around 78 kg. I own a few skis including the v12, fits me perfectly so there shouldn't be an issue for you.
13 years 8 months ago #14105 by Zephyrus
Replied by Zephyrus on topic Re: Epic V-12 body fit?
What is the designed ideal paddler weight for the v12?
I've read in a few places the v10 was designed ideally for a 200-220 pound paddler.
13 years 8 months ago #14107 by 1xsculler
Replied by 1xsculler on topic Re: Epic V-12 body fit?
I'm not concerned about body weight but only height and leg length.
13 years 8 months ago #14112 by Kocho
Replied by Kocho on topic Re: Epic V-12 body fit?
I'm 6'4" with 36" inseam (at least) at 185-190lb and the foot well is too short for me by a couple of inches and the seat is a bit too tight. I suspect both will be just about perfect for you length and width-wise...
