starting angle on an Epic small-mid for a novice?
13 years 9 months ago - 13 years 9 months ago #13144 by 1xsculler
Want recommendations as to blade angle setting and length for a novice using an Epic Small-Mid, 210-220cm.
Last edit: 13 years 9 months ago by 1xsculler. Reason: mistake
13 years 9 months ago #13146 by Kayaker Greg
210cm and I like 53 degrees.
13 years 9 months ago #13159 by Rightarmbad
I think it depends mostly on how vertical your stroke is.
The more vertical generally the higher twist.
But 60 degrees works for most people.
45 degrees can be helpful in really strong side winds sometimes.
Just get an adjustable one and find out what suits you.
13 years 9 months ago #13166 by SDisle07*
Also need to consider paddler height. I am 6'1" and find that setting my paddle at 209 cm with 60 degree feather angle works best. If paddling flat water, I may set the length a bit longer at 212-215.
Jon
