Small adult and Nelo Maxi kids ski?
  • slow
4 years 5 days ago #39960 by slow
I've seen people who are well over the recommended weight limit for a low volume boat paddling a low volume boat, but I haven't seen any adults try to use a smaller kids ski. How large of an adult can paddle the Nelo Maxi?
I can try one out, but it's a very long drive and I'd rather not make the drive if there isn't any chance I'd fit, which I think is fairly likely given the boat's listed age range (9-12). Does anyone know how large and heavy a paddler can really fit into the boat?
The boat lists its suggested upper weight as 50kg. I'm currently 60kg, which is well above that, but when I was climbing and actually watched my weight, I was 51kg, which seems close enough that there shouldn't be a problem on weight, and I've always had an easy time controlling my weight when I want to, so I could get to the necessary weight range if 60kg is a bit too much.
Size seems more likely to be a problem, though, since 12 year olds tend to be quite small when compared to adults. I'm 5'8" with a 31" inseam, 28" waist, and 36" hips. I was a couple inches smaller on waist with slightly smaller hips at 51kg, but 35" hips would still be fairly large on a 12 year old as would a 31" inseam.
Alternately, if anyone can suggest another tiny ski, I'd be interested in that if the boat fits. The limitation here is that I live in a ground floor apartment that has enough space to fit a ski inside, but I have to go around a corner which limits how long an object can enter my apartment. At 4.2m, the Nelo Maxi should be able to squeeze in, but a 5m ski would be questionable. A Carbonology Splash might also be able to squeeze in and looks like a better fit for my size and weight, but I don't know where I'd be able to try one.
4 years 4 days ago #39961 by zachhandler
V5? Surprisingly fun if waves are steep.
The following user(s) said Thank You: slow
4 years 4 days ago #39962 by teuntjeremi
With this weight I recommend the sec gen Nelo 520 (I am of similar weight). The splash is much more tippy.
  • slow
4 years 3 days ago - 4 years 3 days ago #39968 by slow
Replied by slow on topic Small adult and Nelo Maxi kids ski?
Interesting idea. I see local V5s for sale on FB marketplace and craigslist all the time. I'll see if I can try one out!
At 5.2m, I think the 520 might be a bit long to get in and out of my apartment.
Last edit: 4 years 3 days ago by slow.
