- Thank you received: 0
wobblypaddler wrote: I really enjoy paddling the boat, I was having "tight hip" issues which completely disappeared with the Orca.
AR_convert wrote: Interesting to hear you say that, that is why I was interested in trying this ski. I am suffering from Chronic ITB issues that seem to stem from hip/glute tightness. I have had all manner of treatment without success and in desperation more than anything resorted to padding up the seat up my ski to lift my butt out of the tightish bottom of the bucket. It's too soon to know if this may have been the cause but if it was it wasn't obvious over the 8 months I've been paddling my new ski.
Boef wrote: Bingo on this one. Have exactly the same problem from a deeper bucket. Hip pinch appears almost uncurable. I've been to a doc, chiropractor (injections to bursa didnt help), physios, sports therapists. gonna give the tennis ball a go. Its absolutely due to posture and the seat - I had a seat made up by Jamii in Cape Town - that resembles a k1 seat - and that made the discomfort bearable.
To put it differently I've never heard of a person paddling a flat xt bucket complaining of hip pinch. Seems the Orca may be different bucket.
thanks all for the responses.
Kayaker Greg wrote: Not sure if ITB is the same as sore hip flexors? Thats the issue I got paddling my Epic V10L, changing to a Stellar SES solved the problem as the hump was a lot lower.
Rightarmbad wrote: How the hell did you fit in a V10l?
I'm the same height, but no way I can get into one.
A V12 is maxed out for me.
AR_convert wrote:
fredrik wrote:
2 typos in the one-liner.....
My solution to avoid but pain is to cut/fit a rectangular shaped minicell piece in the middle of the seat. I use standard carpet tape to fix it as it is easy to remove.
My approx size 6,5 x 8 x 1,5 cm (cut the top edges at an 30-45 degree angle to avoid rubbing. Fitted right you will not feel it.
A photo or two would be great...and post them in the "Hip Pinch Thread! Cheers.
fredrik wrote: Here are the pictures of the butt pads.
When I came home I measured this pad in my Elite SL to be 11 x 7,5 x 1,0 cm and 12 x 7,5 x 1,5 cm in the Evo
If you want to give it a try, I suggest you test ride it first with tape before fixing it with carpet tape.
Hiro wrote: sit in some sand... you'll get a mold of your bum.
