- Thank you received: 45
I used to get pretty sore shoulders too. They now hardly bother me at all and I put that down to:
1. theraband exercises to strengthen rotator cuff
2. sticking to safe technique
3. change of paddle from an olympic-associated brand to the Gara Odin small with a more flexible shaft and slightly smaller blade.
4. avoiding flat out sprints with the associated loss of form.
When I do sprint for a wave I drop the paddle angle a bit and really try to make the legs and rotation do most of the work.
So the conclusions of this thread worked, to a point. I was able to significantly reduce rear delt fatigue while increasing power.
Then eventually, with the increased power they were the first to go again. Out of frustration I let them get to a point where they were painful (I usually am really strict with workouts where I stop before execution drops and long before any pain sets in.)
I then let my body figure out how to make them not hurt (given how strained they were in this situation that meant not use them) and the answer was a significantly more vertical paddle shaft at the catch. Suddenly the pain was gone.
I can also better feel the small elastic spring off of the paddle lock JD was talking about.
The one thing I have not seen mentioned is a focus on Posture.
I struggled for a long time with a natural tendency to curl forward especially on harder efforts to reach out for my catch. Strangely, moving my foot brace back, closer to me changed everything. (stick with me here for a minute) when my legs were reaching to far (I still had a fist size gap between bottom of knee and hump) it pulled me down into the bucket and caused bad posture.
Flash forward, I move my feet back, come out out of the slope of the bucket and BOOM everything changes. Straight back is critical to leg drive impacting rotation. (Side note, my tailbone used to get sore from pushing it into the bucket when driving legs) So, when my back got straighter, 4 years of muscle development went partially out the window. Suddenly arm and shoulder strength became secondary to Lats and Abs. It took a couple of months to really stabilize my core in a new way, but Leg drive took on a whole new meaning, rotational forces changed and my gold swing went to hell.
Pay attention to your posture, it may be the roof of all evil
If you put a block at the bottom of the footrest under your heel it has the same effect as bringing footrest closer. It also lessens the acute bend angle of your ankle more in line with k1 posture, this help you be over the stroke and helps us old blokes not to slouch. Good for flat and calm water paddlers.
So i used to just do an extra layer of traction pad on the bottom third of the foot plate. On the vega the footplate pivots freely and also eats into the boat despite the rubber padding. Maybe sand gets caught under there. I have only done one paddle with 2 layers plastic slat from cheap venetian blinds taped to the floor. Obviously dont want the heels resting on the lift or it will make posture even worse. But if yours eats carbon mine will not last long at all.
