Replacement rudder for Epic V10 Sport
14 years 9 months ago #8060 by kiwial
The new Epic rudders we have, have a slightly smaller shaft diameter than previous years. not enough to worry about but probably accounts for what you are feeling
14 years 9 months ago #8064 by Kocho
Probably not enough to cause issues, but certainly enough to "worry about". At least I do... I don't like things to wobble about if they do not have to.
I can't see a good reason for it to wobble so much other than sourcing and matching of parts. And don't believe there is a technical reason such as intentionally creating a big clearance to avoid seizures, etc. - but who knows... In my case the clearance is enough to accept a full wrapping of a soda can layer, so it is not that little...
14 years 9 months ago #8069 by vatis
Thanks Epic! But should the rudder have more resistance, to provide more stability in a crosswind, for example? If so, what's the best way to add more resistance (so it takes a little more push of my toe) to it?
14 years 9 months ago #8071 by Dicko
The last thing you want is a rudder with resistance. Everything should move freely.
14 years 9 months ago #8077 by nell
Vatis, I don't think you can increase the resistance of the surf rudder very easily -( I suspect you are talking about the surf rudder). As was written above, it turns with very light pedal pressure because it's balanced 50/50, or 40/60 or something. You need to "unbalance" it more so that you feel resistance to pushing on the pedal and I think the only way to do that is to either bend the blade backwards relative to the shaft (and then sand it to fit) or to use a small cutting tool to move the shaft forwards in the blade. Both are very possible to do but take a bit of commitment and the chance that you'll ruin it. Or, you could get the middle size universal rudder which works very well, or get a nonbalanced rudder from an independent rudder maker. Erik
14 years 9 months ago #8078 by Rightarmbad
Or simply do my self centering mod that I linked earlier.....
