integrated kickback rudder
15 years 3 months ago #6670 by outriggerbev
stabbed my stellar with the back of the rudder two days ago on a high flying rock-its in getting repaired-it happens -probably more than everyone realises-but doesnt have to-why not have an integrated kick back rudder-not at the back of the boat like the normal kick back rudder-but in the normal position-around a meter in from back -but its a sealed unit-so its easily made with the boat(or built into the boat aftermarket) and has a certain tension which kicks back at the appearance of undersurface nasties -or simply sitting the boat on the ground!!
15 years 3 months ago #6671 by Sandy
Replied by Sandy on topic Re:integrated kickback rudder
good idea , would involve lots of parts ! , check out "Keri-tek" with a google search , they make a retractable skeg/rudder combo all in a cartrige and used in sea kayaks. Kinda cool but again , lots of parts and heavy , also sorting out and routing control lines , pedals etc....... my last sea kayak i ordered custom without skeg , the hull shaped lended itself to this (very balanced and not skeg dependent). NOT like a surfski which is I am sure you know very dependent on the rudder. Point being I ordered the boat with simplicity and more space in the aft compartment for multiday trips. I personally prefer the mechanisms (rudder on a ski) to be simple , strong and low maintainace (all = SEAWORTHY). If you have lots of parts you have more chance of them failing (aside the catastrophic failure of whacking a reef or a hard run aground). I am sure others will mention the weight. Kinda intrested to see if Epic will evolve the hull integrated rudder to surfskis?
15 years 3 months ago #6672 by Mulletman
wouldn't the rudder have to be in exactly the right position for this to work? Skegs only move up and down, no side to side variables..
