bullet scuppers
15 years 11 months ago #4731 by Moll
Replied by Moll on topic Re:bullet scuppers
Rightarmbad wrote:
You need longer legs :laugh:
I assume this was directed at me??? If so longer legs won't help, I am already over 6'
The holes are ight at the front of the footwell.
Current Quiver:
- Think Evo
- XT Double
- Popes Big Foot Assegai K1
15 years 11 months ago #4732 by Rightarmbad
Replied by Rightarmbad on topic Re:bullet scuppers
Block em up and fit a bailer further back.
  • gingerninja
15 years 11 months ago #4741 by gingerninja
Replied by gingerninja on topic Re:bullet scuppers
Thanks heaps for the info, can you give me a cost for a couple of scupper kits and a contact .
thanks heaps
15 years 9 months ago #5037 by Moll
Bumping an old thread here but our winter is now all but over so things are warming up. My temprary solution to keeping cold water out when paddling on flat was to simply insert plastic tubes that fitted snugly in the scupper holes. This means when getting in there is no water coming in to the cockpit. there is just some splash obviously but at the end of the paddle there is still not more than a cup of water in the footwell so the jewels can stay warm in winter. :woohoo: I tried plugging them but the plugs tended to be pushed out, with the tubes there is no pressure build up when the scuppers are below the water level. Also meant no modifications to the boat required and easy enough to remove when not needed.
Current Quiver:
- Think Evo
- XT Double
15 years 9 months ago #5038 by superted
Replied by superted on topic Re:bullet scuppers
robin.mousley wrote:
In two weeks time we'll have the shop up and running again. We'll be selling the bullet scupper kits featured in the article Bullet Scuppers .
We can post the kits anywhere in the world.
Where is the link to the shop??
15 years 9 months ago #5041 by Dicko
Replied by Dicko on topic Re:bullet scuppers
Hi Rob,
I have a 2009 model surf70 pro and a mate has a new green 7.
My bullet scuppers won't start "gurgling until I'm doing about 13kph, wheras the green 7 scuppers gurgle at about 8kph and start screaming not much faster than that. The scupper shape is slightly different. My boat always has 2-3 centimetres of water in the cockpit, and the green 7 is boat dry. Obviously the shape of the scupper is important.
How difficult is it to change the scupper hood alone?
15 years 9 months ago #5044 by timforan
Replied by timforan on topic Re:bullet scuppers
I will be selling polypropylene bullets in the next couple of days that can be retro fitted currently to Fenn skis. These have been machined after trialling different shapes. They start to constantly gurgle around 9.2-9.5km. I will post some pictures shortly.
15 years 9 months ago - 15 years 8 months ago #5074 by timforan
Last edit: 15 years 8 months ago by timforan.
15 years 9 months ago #5083 by latman
Replied by latman on topic Re:bullet scuppers
Is that woven carbon over the solid polypropylene or hollow ?
15 years 9 months ago #5084 by timforan
Solid polyprop. This is a thermoplastic. Weighs 8 grams
15 years 9 months ago #5085 by Rightarmbad
Is there a method to the madnesss with the texture on the scuppers?
15 years 9 months ago #5086 by YBA/Jim Murray
Replied by YBA/Jim Murray on topic Re:bullet scuppers
What adhesive is compatible with polyprop and boat gel coats?
J.
15 years 9 months ago #5087 by timforan
I just applied them with silicon. I dipped my finger in turps and rubbed a thin layer of silicon on the bottom of the bullet. Once in place I rubbed the edges of the bullet with turps so no silicon was visible. If your not happy with the position you can easily remove them with turps. Make sure you don't use acetone as this will strip the paint.
15 years 8 months ago - 15 years 8 months ago #5218 by timforan
The bullets are smooth finished as shown in the pictures. They come in two sizes for the older smaller scuppers and newer larger scuppers.
15 years 8 months ago #5220 by Pete
Replied by Pete on topic Re:bullet scuppers
Sorry ....but can I bug you all as I have been following this and even gone back to the original thread.
Is this just if you paddle in cold climates and dont want any water in the well ?
I have a Epic and actually took note last paddle back and couldnt really see to much water in there to worry me ( plus it was gurgling)
Could someone just give a quick over view on a scupper please.
Ta :unsure:
15 years 8 months ago #5221 by timforan
No it is to help drain the footwells quicker and improve water flow over the hull.
15 years 8 months ago #5225 by Dicko
I didn't think the bullets were designed to make the water drain more quickly. My understanding was that they decrease the drag from the scuppers, which allowed red 7 to have three scuppers instead of one. The increased drainage in the red 7 is because it has more holes in the bottom.
It may not improve your drainage, but you'll be slightly faster.
15 years 8 months ago #5226 by AndrewN
Replied by AndrewN on topic Re:bullet scuppers
They are absolutely designed to make the ski drain faster. There is the side effect that it decreases drag but on the purpose made scuppers, the holes are waaaay bigger and allow far faster draining.
15 years 8 months ago #5228 by red_pepper
Replied by red_pepper on topic Re:bullet scuppers
Are there any bullet scuppers made for the stock Epic bailers? I would like to add one under my V10L for drag improvement (it drains fine as is), without having to grind off the current bailer. Before going that far with modifications, I would probably just install a canoe bailer as in the V12 and have a flush bottom.
15 years 8 months ago #5229 by Pete
Are we talking huuuuge drag reduction or .000001% try paddling a speccy during the week then go to a ocean ski on the weekend - its like christmas every time
