What are people using for paddle grips?
8 years 11 months ago - 8 years 11 months ago #29494 by davgdavg
I'd like to increase the diameter of my paddle a little by putting some sort of grip on there.
What are people using? (I thought about bicycle handlebar tape, which would be a nice feel, but I think it would lose adhesive quickly from the salt water.)
Last edit: 8 years 11 months ago by davgdavg.
8 years 11 months ago #29495 by JohnK
Tegs grip tape, tennis racquet overgrip, standard electrical tape or hockey stick tape and of course surf board wax for grip
Each comes with its pros and cons.
  • fredrik
8 years 11 months ago #29497 by fredrik
Replied by fredrik on topic What are people using for paddle grips?
I have tried it all but I suggest just sanding down the grip area on the shaft. try 600 grit first. and adjust up or down as you prefer. Holds a long time and easy to "update" as needed with a consistent result.
  • agooding2
8 years 11 months ago #29516 by agooding2
Replied by agooding2 on topic What are people using for paddle grips?
I use the Burnwater Fusion grip tape, holds up better than tennis racket tape and waterproof and easier on the hands than wax.
8 years 11 months ago #29520 by M.v.E.
I am using bicycle handlebar tape made out of cork. It works great. I am using it for many years now and never had to replace it . I tried tennis racket tape before but that was totally useless.
Current Ski: Nelo 550 L
The following user(s) said Thank You: davgdavg
8 years 11 months ago #29522 by LakeMan
I wear a pair of paddling gloves and they have worked great. Helps when I carry the ski too.
8 years 11 months ago #29535 by feeny
Ive been using paddle gloves too. Also helps prevent blisters. I form callouses OK, but with gym work etc, they tend to blister up from time to time, especially if I change from paddling in cold to warm water.
So, on with the gloves, blisters and grip solved!
8 years 10 months ago #29599 by davgdavg
Thanks for the replies.
Gloves in 85-90F (maybe 34-37c more or less?) weather with 80 degree water is a very unappetizing prospect. I thought about sanding or wax, but I also want a larger diameter.
If bike tape has worked for some people I'll probably give that a try since I have a lot of experience with that and like the grip.
Thanks again
--David
8 years 10 months ago #29646 by zachhandler
I have had good luck with self fusing silicone tape. for example:
www.amazon.com/Rescue-Tape-Self-Fusing-S...ngular/dp/B00AZOK55G
8 years 10 months ago - 8 years 10 months ago #29647 by feeny
The gloves I use are fingerless and a very, very light (on the back of the hand, padded on the palm of course) and actually specifically designed for hot conditions.
www.seatosummit.com.au/products/paddle-a...f50/?ref=watersports
Last edit: 8 years 10 months ago by feeny. Reason: links
8 years 10 months ago #29776 by PeteCress
I always used the stuff they put on windsurfer booms: attached with contact cement.
Recently got a new paddle, and had run out of the stuff, so I used bicycle handlebar tape on the new paddle.
Not bad at all. A little noisy as the hands squeek when slipping, but overall satisfactory.
OTOH, if I come across some of the windsurfer boom covering, I will go back to that.
8 years 10 months ago #29786 by Mjwashington
I just use electrical heat shrink. It gives good grip and still allows me to "feel" the paddle.
8 years 10 months ago #29789 by WingSuit
That rescue tape works extremely well for me. It feels tacky but not too much friction like jockey tape. I line up a small length of small diameter cord under it, down the length of the shaft, to mark the rotational position of the paddle in my hands, an old whitewater trick. That little cord bump needs to be under my index finger knuckle joint. I also use thin nrs gloves since I get these nodules on my tendons from a medical condition called Dupuytrens Syndrome. Used to get blisters under my callouses from that. Good for sun protection too.
8 years 10 months ago - 8 years 10 months ago #29790 by WingSuit
thats hockey tape, not jockey.
Last edit: 8 years 10 months ago by WingSuit. Reason: Double post
8 years 9 months ago #30001 by red_pepper
I've been using bicycle handlebar tape - cork or gel - for a few years now. I secure the ends with electrical tape. I have a few arthritic finger joints that make it painful to paddle a "bare" shaft, but I do well with the padding of the handlebar tape.
8 years 9 months ago #30103 by owenw
I have always just used a lightly sanded shaft and my callouses (Epic Mid Wing paddle). My wife (a very handy flatwater marathoner) used to use tennis racquet tape, but for the last couple of years has done away with the tape and just uses a lightly sanded shaft (Jantex Gamma S paddle) and wears sailing gloves for both her ski and K1; she has small hands.
