epic paddle question
10 years 9 months ago #24849 by jonny250
Hi, could someone with an epic paddle help me with this please - pic attached shows the clamp for the paddle connection lever; i noticed theres a thread on the inside of the lever, but no screw there - i'm just wondering if there was and its fallen out?
i would be grateful if someone could check theirs and let me know :)
thanks
J.
  • photofr
  • photofr's Avatar
10 years 9 months ago #24852 by photofr
Replied by photofr on topic epic paddle question
Hard to tell…
It looks as though it's a plastic plug used to fill the two holes… two holes where some sort of tool or machine was used to clamp / hold the paddle at one point. I'd send you my "plugs" if I could take them off, but they are in there. On the other side of the coin, I really wouldn't worry about it… at least, that's my take on it from observing two of my paddles.
Ludovic
(Brittany, France)
10 years 9 months ago - 10 years 9 months ago #24853 by merijnwijnen
Replied by merijnwijnen on topic epic paddle question
I happen to have a new one lying around, I still want to replace my old rotating thingy.
You are missing a small set screw that is ment as a security to keep the lever in place (although on my version the lever does not come of without the screw).
I took it out to show you. Have a look:
Seakayak, flatwater racing and a surfski on order.
Looking for other ski paddlers in South East Netherlands (Maas / Waal)
Surfski: Nelo 560 on order :-)
K1:Kirton Tor
Sea kayak: NDK Explorer HV
Last edit: 10 years 9 months ago by merijnwijnen.
The following user(s) said Thank You: jonny250
10 years 9 months ago #24854 by Flowmaster
Replied by Flowmaster on topic epic paddle question
screw it ;)
...ooooO...................
...(.......)......Ooooo....
JUST LEAVE FOOTPRINTS
10 years 9 months ago #24860 by Newbflat
Replied by Newbflat on topic epic paddle question
Bought yesterday.
FENN Bluefin S
Epic V8 double gen 2
Lot and lots of DK rudders.
Had:
Stellar SEL excel (gen 2)
Stellar SR excel (gen2)
Stellar S18s g1 (excel)
Epic V10 Double (performance)
Stellar SR (gen 1)
V10 sport (gen 2)
V10 (Gen 2)
Beater SEL (gen 1)
10 years 9 months ago #24861 by Ranga
Replied by Ranga on topic epic paddle question
The screw is not just a security item, it is a vital part for the tension in clamping. The plastic lever is the main clamp opposing the Stainless steel bar nut on the opposite side, it makes the surface area large enough to not wear out the small hole the main clamping screw goes through.
10 years 9 months ago #24862 by jonny250
Replied by jonny250 on topic epic paddle question
Thanks guys, thats what i figured. i will get it sorted.
cheers, J.
10 years 8 months ago #24944 by jonny250
just in case it helps anyone else, epic said its a stainless steel 2.5 x 6 mm flat head screw.
i had to order a pack of 10 as i couldnt source any locally [small island thing!] so if anyone else needs one... let me know! :)
