Shortening paddle blades
10 years 11 months ago - 10 years 11 months ago #24336 by Hiro
In another thread I explained how I downsized an old Epic mid wing for my 10 years old son.
www.surfski.info/forum/17-equipment/1845...le-sizing.html#24337
I grinded the blades to be 46cmx14.5cm. (was 50cmx16.5cm before).
Now, on the edge, I can see the foam core inside the blade. Is it OK to leave it like this ? Do I need to seal it with epoxy ?
Last edit: 10 years 11 months ago by Hiro.
10 years 11 months ago #24338 by Ranga
Replied by Ranga on topic Shortening paddle blades
It is not ideal to expose the core, but it is a closed cell foam so it will not soak up water. It will however not be very strong on the edge as there is very little material either side of the core, any impact will damage the edge quite easily.
The main issue is the balance and stability of the blade through the water. Yes you can paddle with it but to get the best stroke it might be difficult as the blade will want to track differently in the water to what it is designed for. Also the thick edge will make quite a splash and noise on entry to the water, not matter what you do this will not go away which could be frustrating.
The following user(s) said Thank You: Hiro
10 years 11 months ago #24339 by Flowmaster
Replied by Flowmaster on topic Shortening paddle blades
My advice would be to seal it, or use these blade edge covers which they use for Sup paddles. the splash would be there, but the blade wil last. :)
...ooooO...................
...(.......)......Ooooo....
JUST LEAVE FOOTPRINTS
