DIY weed guard
11 years 10 months ago #21630 by ptomblin
DIY weed guard was created by ptomblin
Does anybody have any suggestions for how to make a weed guard? The one that Epic supplied with my ski fell off after one day, and I don't want to spend another $25 for one of theirs if it's only going to last a day. Interested in suggestions for materials, how to attach the pieces together, and how to attach the weed guard to the boat.
The following user(s) said Thank You: tony h
11 years 10 months ago #21642 by Bill L
Replied by Bill L on topic DIY weed guard
To attach it if you may want to remove it later, use silicone adhesive.
To attach it permanently, use epoxy, and follow these instructions:
www.huki.com/index.php?page=Bungee_Loops
Bill
The following user(s) said Thank You: J3ZZA, ptomblin
11 years 10 months ago #21665 by red_pepper
Replied by red_pepper on topic DIY weed guard
When you buy the weed guards they'll tell you that the double-sided tape supplied with the guard won't last long; for permanent attachment (actually semi-permanent, because a solid hit with a rock will break it off [the voice of experience]), Epic suggests using a good epoxy (as suggested above). Epoxy worked well for me (outside of the rock incident...).
  • Rod Thomas
11 years 10 months ago #21667 by Rod Thomas
Replied by Rod Thomas on topic DIY weed guard
ptomblin wrote: Does anybody have any suggestions for how to make a weed guard? The one that Epic supplied with my ski fell off after one day, and I don't want to spend another $25 for one of theirs if it's only going to last a day. Interested in suggestions for materials, how to attach the pieces together, and how to attach the weed guard to the boat.
Or you could order a few from
mockepaddling.com/product/weed-deflectors/
50 rand is only 5USD
Even with airmail postage it would be good value...
11 years 10 months ago #21682 by rlh608
Replied by rlh608 on topic DIY weed guard
3M 5200 marine sealant is pretty bombproof, once it cures.
Current ski: Stellar SR Advantage
11 years 10 months ago - 11 years 10 months ago #21798 by Simon Haywood
Replied by Simon Haywood on topic DIY weed guard
DIY Weed Guard - If you have some spare time, a bit of patience and rudimentary fibreglass skills you can easily make them. I made a basic mould using some scrap aluminium angle, a bit of masking tape and some bolts.
Using release wax/agent on the aluminium - Layer up each side with some (200gram) carbon fibre pieces and some chop strand (for bulking up) I used epoxy resin (West) but you could use polyester resin. Once you have done both halves clamp/bolt together I used a third piece of aluminium to give the base a flat/smooth finish...What you should end up with is a T section. Then cut the carbon T section with an angle grinder/Dremel tool to you own shape or desire!
Once you have the profile sorted simply map out on the ski - the exact position - use masking tape to mark out the area - then abrade the marked out area - I use 5min Araldite(2 part epoxy) to glue the weed deflector on.
Current Skis:
Huki S1-R
Stellar S18S - Excel
Stellar SR - Ultra
Skis on order: None!
Last edit: 11 years 10 months ago by [email protected]. Reason: Inserted the images in the post.
The following user(s) said Thank You: [email protected], red_pepper, ptomblin
11 years 10 months ago #21801 by [email protected]
Replied by [email protected] on topic DIY weed guard
Very neat! Thanks Simon!
11 years 10 months ago #21802 by Fath2o
Replied by Fath2o on topic DIY weed guard
Cool idea and looks really sweet!
I just cut and shape a piece from an old surfboard fin and epoxy it on. I just live with whatever color it is. Could be painted though.
11 years 10 months ago #21803 by ptomblin
Replied by ptomblin on topic DIY weed guard
I tried making one out of an old CD-ROM, but the glue I used to stick the two parts together didn't last for a whole paddle. Which is unfortunate because it had the advantage of being thin. A friend made me one out of lexan, and it seems to be holding together - I've tested it on floating seaweed at L2L and the usual leaves and grasses in the Erie Canal and Irondequiot Bay. But I like the idea of Simon's carbon fiber one.
11 years 9 months ago #21901 by lost john
Replied by lost john on topic DIY weed guard
Here is what I made about two years ago out of "preservation tape". Works well against milfoil with this weedless rudder on my Atom.
The following user(s) said Thank You: XV2PS
