Adjustable paddle repairs
11 years 11 months ago #21273 by Dan_81
I noticed today that my adjustable paddle is starting to come loose where internal section is attached to the shaft. Could anyone suggest a good adhesive to use when re-fitting it?
11 years 11 months ago #21274 by antonsa
Replied by antonsa on topic Adjustable paddle repairs
Some are hot glued in and others epoxied. What works really well is the adhesive that they use to put windscreens in. Go to your local auto glass replacement center and ask them to dab some on the inner shaft (that you have removed and cleaned) then re insert - make sure that it is correctly lined up - mark this point before you remove! This glue is great as it sticks like the proverbial and retains some flex.
The following user(s) said Thank You: Dan_81
