Surfski rack problem
12 years 1 month ago #20860 by cody91
Surfski rack problem was created by cody91
I’m trying to mount my surfski to my vehicle while pulling a small camping trailer. Currently the length of my surfski is too long to be mounted on the roof when the trailer is connected to my vehicle because the tail of the ski comes in contact with the trailer.
Has anyone found a rack solution that will solve this problem? I was thinking about possibly purchasing one of these Vbar racks to extend the mounting position forward but I’m not sure it’s the best solution.
goodboykayaks.com/
The other option I’ve contemplated is possibly mounting the ski backwards to reduce the length of the ski that is protruding over the rear of the vehicle. Has anyone had success doing this?
Thanks,
Cody
12 years 1 month ago - 12 years 1 month ago #20861 by Fath2o
Replied by Fath2o on topic Surfski rack problem
If you mount it backwards be sure to secure the rudder to prevent it from flopping around and causing damage.
Does it make sense to mount it on the trailer?
Last edit: 12 years 1 month ago by Fath2o.
The following user(s) said Thank You: cody91
12 years 1 month ago #20863 by cody91
Replied by cody91 on topic Surfski rack problem
Fath2o wrote: If you mount it backwards be sure to secure the rudder to prevent it from flopping around and causing damage.
Thanks for the response. I was actually thinking about removing the rudder while traveling, if I went with this configuration.
I also thought about mounting to the trailer but the shape of the trailer (tear drop) prevents me from securely mounting anything to its roof.
12 years 1 month ago #20864 by sAsLEX
Replied by sAsLEX on topic Surfski rack problem
What sort of car?
There is this option (pardon the CAD)
12 years 1 month ago #20865 by cody91
sAsLEX wrote: What sort of car?
Thanks sAsLEX. I may look into trying that. I have a Volvo XC90 Sport Utility Vehicle. It's similar to the one in your picture. Just a little longer.
My trailer is an RPOD. www.forestriverinc.com/rpod/
I plan to camp out at remote beaches with the trailer and use my ski.
Cody
12 years 1 month ago #20868 by Fath2o
Totally cool trailer. Don't let my wife see it or I'll be buying one!
