How to cut my blades smaller?
12 years 1 month ago #20731 by Ric
I have an old paddle that I want to experiment with - I want to give it smaller blades... :whistle:
Blades are standard fibreglass construction as far as I can tell.
Can I just take a hacksaw and cut away at it? (after mapping out exactly where to cut, that is...)
Or do I need a unique set of tools for cutting into fibreglass?
12 years 1 month ago - 12 years 1 month ago #20732 by Kayaker Greg
I haven't done fiberglass but I've done a few carbon fiber and they were actually very easy to do with first a bench grinder, then a dremel, finishing off with a hand held grindstone for sharpening tools. Use a fine stone on the bench grinder and feel your way into it, its easier than it might first appear. Where a mask or something over your face, I since found out its dangerous not to do so :blush: . At least I did mine outside with the wind at my back, as it should always be right?
Last edit: 12 years 1 month ago by Kayaker Greg.
12 years 1 month ago #20734 by Ranga
Replied by Ranga on topic How to cut my blades smaller?
No problem to cut fiberglass, it is also very safe as the particle size is not small enough to ingest into the lungs plus it is inert, it is an irritant though to put it mildly!
The problem you will have cutting blades down is the core that they were made with, cheaper paddles use cheaper core materials. If you cut into the core the blade might just become a sponge and de-laminate.
12 years 1 month ago - 12 years 1 month ago #20738 by gbowd3
All good suggestions, or you could sand them down by using the road or driveway as a grinder. Done this many times.
You can manoeuvre the paddle up and down to get the right curve. Works great! :)
Then when you're happy, just grab some fine sand paper, or a really smooth road, haha, to finish it off smoothly. Nah, sandpaper is best and I've only done this with carbon blades though.
Best thing is, you can do it right when you test it in the water. There are roads everywhere! B)
Last edit: 12 years 1 month ago by gbowd3.
12 years 1 month ago #20740 by ggc
Replied by ggc on topic How to cut my blades smaller?
gbowds, would concrete work just as well? would you recommend exposed aggregate for initial shaping, then finish off on a broom or float finished slab?
12 years 1 month ago #20751 by Kocho
Replied by Kocho on topic How to cut my blades smaller?
Marble tiles followed by gentle limestone slab application (without shells in it) works best for the finishing touches :P
And keep the Epic web site address handy to order replacement blades in the right size :woohoo:
12 years 1 month ago #20756 by Ric
Replied by Ric on topic How to cut my blades smaller?
What is this "core" material you speak of? ;-)
JK - no need to replace any blades on this paddle if anything goes "wrong" - its an otherwise useless paddle with little resale if any.
Thanks for the tips - anyone in Cape Town will see me at the beach rubbing the blade on tar, concrete and a bit of porcelain tile in the change rooms.
Alternatively I'll try go with the hacksaw approach.
12 years 1 month ago #20757 by sAsLEX
Ric wrote: What is this "core" material you speak of? ;-)
The following user(s) said Thank You: Ric
12 years 1 month ago #20758 by Ric
Thanks, sAsLEX.
I was hoping this ( ;-) ) would show I was just kidding (or "JK")...
I doubt this old paddle has much of a core (neither does its owner...).
12 years 1 month ago #20759 by sAsLEX
Ric wrote: Thanks, sAsLEX.
Someone would have been wondering..... ;)
