Foot pedal cable replacement help
13 years 2 months ago #16302 by shu
Looking for help here.
The stainless cables on my EOS 660 are frayed to the point that I'm out of the water until I replace them. I have never replaced cables before on any ski, so I'm looking for any insights on how to best do it.
I'm unsure if the manufacturer will have pre-fab materials so I'm likely on my own to source and create.
I know all boats are different but I'm guessing it's pretty similar.
Any suggestions?
Thanks all.
13 years 2 months ago #16303 by Wally
The cable is usually 2mm S/S, normally available from rigging suppliers. The connections are usually done with compression crimps but can be done with cable connectors that are tightened mechanically with screws. All this stuff is readily available from the same place you will get the cable.
