position in mako6
17 years 3 months ago #3068 by olivier
position in mako6 was created by olivier
hello
I have a Mako 6, I measure 1m70 for 58kg
I would like her position is the mieu for surf ski
is what to come forward on the seat to move the weight on the front by putting foam behind the seat
Fran?ais
Anglais
permuter
Traduire
17 years 3 months ago #3069 by owenfromwales
Replied by owenfromwales on topic Re:position in mako6
Hi Olivier,
If the ski is too long for you, you can pad the back like you said, or put some foam pads on the pedals and heel-plate, or you could do both.
If you just want to shift your weight forward, you could do like you said, but the further forward you come, the higher your backside will be, making the boat a little tippier.
189cm 90~100kg
Present skis:
2017 Stellar SEI 2G
1993 Gaisford Spec Ski
1980s Pratt Spec Ski
Previous
1988 Kevlar Double Chalupsky
1992 Hammerhead spec
2000 Fenn copy
17 years 3 months ago #3072 by YBA/Jim Murray
Replied by YBA/Jim Murray on topic Re:position in mako6
Given height and weight, foam packing may not work so well- worth a try though.
Would it be an option to look into a smaller ski? Huki makes a ski for smaller paddlers that has had good things said about it.
17 years 3 months ago #3073 by Hiro
Replied by Hiro on topic Re:position in mako6
2 bouteilles d'1,5L , remplies de sable, plac?es en avant du p?dalier devraieent faire l'affaire pour avancer le centre de gravit
17 years 3 months ago #3074 by YBA/Jim Murray
Hiro, I agree that bottles of sand will trim the boat, but wonder how or if handling will be affected in big waves.
Also, Olivier is a small light paddler in a large volume boat. Being a lightweight myself, I can say a big boat can be more of a handfull in strong winds.
Anyway, your thought is a good one, given the cost and hassle getting a boat from abroad, and well worth trying.
17 years 3 months ago #3075 by olivier
Replied by olivier on topic Re:position in mako6
agree therefore must I move my center of gravity, or can you advise me on the length of the paddle
17 years 3 months ago #3076 by YBA/Jim Murray
You can't go wrong with adjustable length paddle- play with it until you find what works best.
