- Thank you received: 19
robin.mousley wrote: Interesting post.
I've not really thought about it from a long distance point of view.
mickeyA wrote: Very interesting about the heel pad. I am imagining keeping foot plate in same location so the balls of my feet and toes stay as is, but by padding only the heels, I effectively push my hips back, but not my head. ... I go to yoga class once a week and certainly stretch before races, but I do have lifelong relatively tight hamstrings, so I have a tougher time sitting low (heels and butt ~same level) and still having slight forward lean ...
mickeyA wrote: Thanks for such good info. I finally got to paddle and I found putting a foam wedge at heels to lower the foot angle, to get toes well in front of heels, helps. Putting pad in lowest part of bucket, sitting higher, also helps. Putting pad in back of seat does make me sit up straighter or rotate my pelvis forward, and feels good, but rubs too much on my lower back.
zachhandler wrote: On the topic of hamstrings - tight hamstrings cause shoulder injuries. Tight hamstrings cause the pelvis to tip back. Then, to stay upright and not fall onto the backdeck, one must bend their spine into a hunched posture. This leaves the upper torso angled forward, which effectively forces one to raise their arms higher in order to paddle. Raised arms cause shoulder impingement and expose the rotator cuff to injury.
I hope that makes sense. Tight hamstrings will impede almost every aspect of the stroke, and also make it hard to get comfortable in a bucket.
I have horribly tight hamstrings and I am really bad about stretching them. I lack discipline in that regard, and I suffer the consequences: bucket discomfort, hunched back, sore shoulders.
