Help to fix my rudder tube
12 years 9 months ago - 12 years 9 months ago #18041 by ptomblin
Rudder tube video My V10 Sport leaks like a sieve in heavy surf, and it appears that the rudder tube is the culprit. How can I fix it?
Last edit: 12 years 9 months ago by ptomblin.
12 years 9 months ago #18042 by PaddleFaster
West System G/flex Epoxy
The following user(s) said Thank You: ptomblin
12 years 9 months ago #18043 by PaddleFaster
Sand around the area first with a piece of 120 grit sandpaper just to slightly roughen up the surface.
Wipe area down with denatured alcohol and let dry...
Mix epoxy and apply around area liberally...
Let cure over night...
