Foam for foot blocks
13 years 1 month ago - 13 years 1 month ago #16272 by 7ender
Foam for foot blocks was created by 7ender
Hey guys,
Anyone know where to get some good closed cell foam, or any other material, that would work well for making foot blocks? The cockpit it my Maki mill is a bit too long.
I bought a camping pad from WalMart, but the foam seems to be too soft. By the time I layer it up to make an adequately sized foot block, it will be way too squishy and prevent leg drive.
Ideas for something else?
Last edit: 13 years 1 month ago by 7ender.
13 years 1 month ago #16273 by Kayaker Greg
Yeah the camping mats are too soft, inferior foam. Here in NZ we have a store called Para Rubber who have all different thickness of foam and its a lot denser, don't know what you have or even where you are but you need to find a rubber and foam supplier for the good stuff.
13 years 1 month ago #16274 by Kayaker Greg
If you go to your local friendly kayak store, sometimes they have some large foam blocks that are removed from kayaks after transportation, I have some which are about 100mm thick and very dense, could make something out of those perhaps.
13 years 1 month ago #16275 by Hiro
Replied by Hiro on topic Re: Foam for foot blocks
either wood blocks or foam from thick slippers
13 years 1 month ago #16276 by zamalek
Replied by zamalek on topic Re: Foam for foot blocks
Go to your local canoe shop and buy a butt pad.Cut to size.They come with glue and backing paper.Peel off and stick on.Easy and simple.
13 years 1 month ago #16281 by 7ender
Replied by 7ender on topic Re: Foam for foot blocks
I think I may have found the solution- Yoga blocks. They are cheap, readily available, and I can cut it to size.
Can anyone confirm that EVA foam is closed cell?
13 years 1 month ago #16283 by PaddleFaster
7ender, yes EVA is a closed cell, rigid foam. Also known as mini-cell foam.
13 years 1 month ago #16284 by PaddleFaster
No eBay APP ID and/or Cert ID defined in Kunena configurationFor those in the US, looking for a good sized block at a reasonable price...
Black Minicell Closed Cell Foam Waterproof 24"x12"x4.5" for about $30
I have purchased a few blocks of this for fabrication projects in the past.
