camera mount for bow of ski?
12 years 11 months ago - 12 years 11 months ago #17109 by 1xsculler
How are you attaching a camera to the bow of your ski, i.e. Epic with a sharp "V" shaped deck top?
Last edit: 12 years 11 months ago by 1xsculler. Reason: error
12 years 11 months ago #17110 by Kayaker Greg
I use the GoPro suction cup mount.
12 years 11 months ago #17114 by EK Sydney
For a bit of angle and altitude I use a Sticky Pod mount with a 10" extension bar. Pic of the mount on my ski & the picture it captures below
12 years 11 months ago #17115 by Sandy
EK , how's that Tide race pace feel compared to your epic ?
12 years 11 months ago #17116 by EK Sydney
G'day Sandy, no viable comparison really, designed for two different things.
12 years 11 months ago #17117 by CoastPop
I use the GoPro suction mount. Works a treat.
12 years 11 months ago #17119 by guitouni
I use the Surfboard mount ( on a Vajda Hawx ). But it requires a ( small ) flat surface, not sure there is one on the front on all boats.
About suction mounts: GoPro states it is not adapted to water sports, you had no problem with it ?
12 years 11 months ago #17120 by CoastPop
I have used the GoPro suction mount on many occasions, even bashing through surf. It has never come loose. I guess one will need to keep an eye on corrosion on the bolts though. I spray WD40 on mine now and again.
12 years 11 months ago #17122 by guitouni
Good to know thank you.
I guess it work only on perfectly flat surface ? No problem to find a location on your ski ?
12 years 11 months ago - 12 years 11 months ago #17123 by Kayaker Greg
I use the suction cup on the front of my Stellars but yes they have a flat surface, have not tried on a curved surface. GoPro have stick on mounts that work very well and I use these on my sea kayak, also have these stuck inside the front of my cockpit and at the rear of my Stellar as well, always tether the camera just in case regardless of what you use. The stick on mounts come in flat and slightly curved so they will work on any ski. Just need to tighten the mounting screws with a philips head screw driver if punching out into waves otherwise the camera can get knocked over on its mounting screws and you will get nice video of your deck.
Last edit: 12 years 11 months ago by Kayaker Greg.
12 years 11 months ago #17124 by rambo
Yes the GoPro suction cups work well on flattish surfaces, but just to be sure fast moving water doesn't force the outer rubber lip up and compromise the vacuum, seal the cup to the deck/upper hull with a few layers of duct tape. Tether always, a spare stick on mount is good as a tether point, make short as possible.
12 years 11 months ago #17126 by Kayaker Greg
I tether back to the cockpit, that way if there is a failure I can pull the camera into the cockpit rather than have it banging around at the front of the ski.
12 years 11 months ago #17128 by rambo
I used to tether back to the cockpit but found after few times when a camera has detached (usually while surfing a sizeable wave) the camera does considerable damage to the hull from a long tether. A short tether ( right next to the main mount) keeps the camera close to the craft and out of most of the waters force. It's an easy dismount to remove it.
12 years 11 months ago #17130 by CoastPop
I use it mounted in front of the cockpit which is slightly rounded on a Fenn XT. I can send pic if you like
12 years 11 months ago #17168 by LaPerouseBay
A friend of mine does a lot of composite work. He let me have some scraps of carbon and foam to make these camera mounts. These are my first attempt at composite work, so it took me a LONG time. :) I'm a woodworker by trade and have a lot of respect for composite guys. Tricky stuff to work with. But the foam machines just like wood. So, nice smooth transitions with some saws, files and sandpaper. Fun project for me.
The results are amazing. 2 layers of carbon, pre-wet on a table and carefully laid on the boat or over the foam. Both mounts are exceptionally light. Super strong. I secure them to the boat with clear packing tape. Exceptionally secure, no need for a tether in the front. Skin tight fit to the hull. No tape in these pics. The rear mount is about a foot off the deck. Thin unidirectional tubing.
IMO, thin tubes and smooth transitions are important out back. I've tried suction cups with wood prototypes and felt it steering the boat.
Also, the deflector on the front mount is necessary. I tried it without - the cam would just lay down. My south shore runs start with zero fetch. Tight bumps early on. So sometimes I need to ram through stuff. If I err on the north shore and jam the nose, no worries. It's raked to help lift the nose.
File Attachment:
File Attachment:
File Attachment:
12 years 11 months ago #17173 by TaffyMick
GoPro adhesive mount works a treat on my Fenn, slightly angled deck but have nearly total adhesion. Have it tethered to the small adhesive safety bracket as well. Also have the orange float pad attached. No problems so far and it has copped a good workout on occasions.
12 years 11 months ago #17187 by Hiro
LaPerouseBay, I've been thinkig of something similar to your rear mount. I want to place the cam higher than deck level and I don't want the cam to move a lot. I'm sure the tripod is the way to go. Where do you get your thin tubes ? What are they sold for ?
12 years 11 months ago #17198 by LaPerouseBay
Hiro, the tubes are 8mm, unidirectional. No idea where they came from or what they are used for. Mike gave them to me and someone gave them to him. If you google carbon fiber tubing you will get several suppliers. Mike says they are fragile, so I coated them with epoxy.
About a foot off the deck works ok for me. Any higher and I worry about the swing weight. Too low and the cam is always underwater.
12 years 11 months ago #17214 by Jean-Pierre
Hiro,
about tubes, they looks like to pieces used in kites.
Sort of this piece: www.bilboquet.com/upper-leading-edge-for...c2,uc287,p16742.html
You can find different weight and construction (hollow or full)
12 years 11 months ago #17215 by JML
Have a look at the RailBlaza mounting system that can be used for a whole lot useful of applications from mounting cameras to gps and rod holders. You can download the full catalogue at this link.
dl.dropboxusercontent.com/u/51190097/FL_RailBlaza.pdf
