- Thank you received: 0
Rotating the hip forward to me set up the whole synchronization to the whole stroke, leg drive reacts to this, with the shoulders arms and torso following the hips. The paddle staying parallel to chest. All the arms do is spear (slide sideways from one side to the other) and exit (tilt from one side to the other) without ever moving out of the same plane as the shoulders. Punching forward leads to late exits )and vis versa) and the shaft not staying parallel to torso. Overhead or nose camera angle in slo mo will easily pick thi supDon't obsess about speed. Really, don't.
There is always someone much, much faster. The only valid speed comparison is with the person next to you, who is at a similar stage in their paddling journey. Even comparing your own paddles, day to day, isn't good. Water and weather affects speed a lot.
Ivan did a whole series about paddling (something to keep him occupied during lockdown). It is worth watching.
Key points:
Don't let top hand drop.
Keep your paddle stroke short. If you are 'locking your arms', driving from legs and rotating, your paddle will come out of the water nice and early.
None-drive side hip - rotate this forward. Oscar says to push it forward, which sounded wrong to me. I tried it, and it really improved my rotation.
Start at the bottom and work up, you build a house with solid foundations, we build our stroke from a solid connection with the legs. Obviously can't see your leg drive, but your hips aren't rotating at all, indicating not much of coming from the legs. That's the first thing to address. From there, rotating the upper body, almost none happening. You're blade placement is short, and "duck feeds" as you pull it back. Hands are too low, and your shoulder is in a weak position at that height. Think how you'd set yourself up for a push up, and the position your shoulder is in then in terms of stability and strength. Once in that strong and stable position, you can establish a strong catch and rotate around that point to generate your forward propulsion.
Keep working at it, and keep having fun on the water.
