Fenn IV = Brasca IV Min or Brasca IV Max
18 years 9 months ago #932 by MFB
HI,
Do you guys know if the Fenn IV is the same as the Brasca IV min or max? It just says that its " Mid-volume paddle, teardrop design modeled after the Hungarian Brasca lV, great for surfski."
How many sq cm is the Fenn IV?
18 years 9 months ago #933 by [email protected]
I asked Keith and he thinks it's closer to the min - it's definitely a smaller, long distance blade. It has an insert (i.e. it plugs into the shaft) instead of a collar fit to the shaft - he believes that's stronger. He says he's just started making a new, bigger blade that some of the guys in East London are changing to - he hasn't given it a model number yet. It was based on an old paddle that he used to use - he's made the blade slightly smaller than it was, but it's bigger than the Fenn IV.
He doesn't know the sq cm size of the Fenn IV blade!
18 years 9 months ago #934 by MFB
Epic mid wing is 750, small wing 735. Brasca IV min is 735, max 765. Fenn IV is ...
Is Bratcha IV modelled after brasca IV too?
18 years 9 months ago #935 by MFB
I emailed Zsolt on what Kajner model he uses. I also asked what Brasca IV paddle I should use for surfski if its the min or max. According to him, the one he uses is basically the same (Kajner) as the Brasca IV. As per his advice, I go for the min instead.
I just spent 3 hours paddling today. Aside from the debris getting stuck in my all weed rudder (hehehe), paddle is just perfect for surfski!
Thanks Zsolt!
  • No posts to display.
