- Thank you received: 0
I've got an older Nelo 510, and I've been having trouble dealing with moving water. An instructor suggested that I use a removable seat pad when I'm paddling on calm water just to work on my balance. Probably most of my paddles are quick 45 minute to an hour outings after work (on Redwood Creek for people in the SF Bay area), which is pretty calm except for occasional powerboats.
Anyway, I'm looking to set up a system that's easily removable, slick enough to rotate on, works on rotomolded plastic, and hopefully can be adjusted for height. I know Epic makes stackable seat pads "for compost ski use only;" are these unlikely to stick plastic? If I were to make my own setup from foam kayak padding, what would I put on top to allow rotation?
